71' Cutlass Lower fender mount bolts
Old Nov 12, 2013 | 03:41 AM
JCMC64's Avatar
JC
The lower fender mount cage nut and bolt...what size and thread count are these mount bolts? Thx.
Old Nov 12, 2013 | 06:29 AM
The Bug Man's Avatar
Got mine at NAPA
Old Nov 12, 2013 | 07:18 AM
JCMC64's Avatar
JC
Thx. I need to know what the original OEM bolt sizes were for my own knowledge base.
Old Nov 12, 2013 | 02:28 PM
JCMC64's Avatar
JC
Help?
Old Nov 13, 2013 | 05:42 PM
JCMC64's Avatar
JC
Some help please?
Old Nov 13, 2013 | 06:58 PM
Schne442's Avatar
No it's not a parts car!!
3/8-16 X 1 3/8 9/16 AF 1.31" CONICAL WASHER 3986563
Info provided in AMK Products web site pg. 111. Part # B-11964
Old Nov 13, 2013 | 07:22 PM
JCMC64's Avatar
JC
Thank you kind Sir!!
Is that a good site to use for this kind of stuff? I have a bit of a proper bolt and nut, etc fetish.
Old Nov 13, 2013 | 07:30 PM
Schne442's Avatar
They sell almost every bolt for your car. they have most GM part numbers. more Chevy stuff listed but any GM A body used similar part numbers.
get the bolt part number from your assembly manual than look on their site for the correct match.
Old Nov 14, 2013 | 02:53 AM
JCMC64's Avatar
JC
Gotcha. Thx for the good info/ help!
Old Nov 14, 2013 | 05:24 AM
JCMC64's Avatar
JC
Schne442
I found the bolts on AMK website. How about the U nuts? The ASM number is 387730. When I looked it up on AMK site, it isnt listed...that I can find anyways. U and J nuts are on pg 56-59. The ASM shows it should be U nut for 71' Cutlass 442. Thx in advance.
Old Nov 14, 2013 | 06:48 PM
Schne442's Avatar
The U nut is on page 60, part # B12010. It has been a while but I think I called them and they said that B-11964 was the correct bolt. They do not list all the GM part numbers so sometimes I had to measure the old bolt and find one that matched. If you get their print catalogue the pictures are actual size so you can match the part up against the picture.
Old Nov 18, 2013 | 06:01 PM
JCMC64's Avatar
JC
Thx Schne. But those arent oem correct , should be j nut with square 9/16 or so nut, as you probably know. I got so curious I went back to junkyard to a 72' Cutlass Ive been stripping and dug into lower front fenders. I would of done this sooner except the area is so badly rusted I knew it would be lot of work to dig out the J nuts. I got all four but only 3 are usable. These are the square oem type nuts. Will post pics for others that are curious about correct oem version.
Old Feb 15, 2014 | 10:02 AM
Rocketguy's Avatar
Old Feb 15, 2014 | 01:01 PM
JCMC64's Avatar
JC
Originally Posted by Rocketguy
What happened to above post?
Old Feb 15, 2014 | 01:36 PM
Rocketguy's Avatar
I was confused
I confused your lower fender bolts with the lower plastic inner wheel well bolts.
Sorry dude
Old May 22, 2020 | 03:35 PM
kencpless@gmail.com's Avatar
JCMC64 is absolutely right … correct fastener is shown in the picture. The original was of a "J" nut design with a much more substantial square nut.
nolabigdawg
Oct 25, 2014 11:50 AM
STR-8_CHARGIN
Suspension & Handling
Oct 31, 2013 08:11 AM
Kiwicutlass
Nov 25, 2012 02:33 PM
bittersweet71
Aug 16, 2010 07:01 AM
bigbrother
May 18, 2008 09:13 AM
