66 F85/Cutlass trunk drop offs?
Old May 19, 2024 | 06:56 AM
runt's Avatar
Does anyone know if any of the GM trunk drop offs sold will fit the 66 F85/Cutlass?
Old May 19, 2024 | 07:31 AM
nicks1966's Avatar
I have tried a few others and none will work without major cutting and forming to fit.
good used is the only choice.
Old May 19, 2024 | 08:02 AM
runt's Avatar
Thanks. I really only need the passenger side and just the bottom couple of inches where it's spot welded to the bottom of the quarter panel. You think I'd be able to cut that portion off one of the ones made for other models and butt weld it in? I'm just kind of thinking finding a good used one is going to be a challenge and trying to think of an alternative.
Old May 19, 2024 | 05:03 PM
Goldiewilson4mayor's Avatar
Goldiewilson4mayor
if you only need the bottom couple inches and not the curve toward the front. Just form it up out of some 18 gauge. I use chevelle ones from amd close enough for me . I cut off the top flange and the back 8 inches. On my 29 Cutlass using these pieces. All the undercoating hides most of the metal anyway
Jul 8, 2021 12:02 PM
doc
Mar 10, 2013 06:06 PM
twill
Jul 17, 2011 03:53 PM
Warhead
Dec 26, 2010 05:51 AM
Colorado Olds
Feb 4, 2009 07:13 AM
