Trunk lid rust
Old May 21, 2024 | 07:47 AM
kitfoxdave's Avatar
Trunk lid rust
I have a 72 cutlass convertible with a replacement trunk lid from a 4 door cutlass sedan. There is some inner surface rust down by where the inner and outer sheet metal come together. What product would you folks recommend to convert / seal this to prevent that nasty ugly rot through?
Would not be averse to getting a composite deck lid if anyone knows of a good quality type available.
Thanks in advance!
finally retired and getting enough honet do's out of the way to start focusing on the car again.
Old May 21, 2024 | 03:50 PM
Supernice88's Avatar
Art S
https://ocean-supply.com/skyco-ospho...-osphoq-osp-4/
Old May 21, 2024 | 04:01 PM
redoldsman's Avatar
Proud Viet Nam Veteran
That looks like a good product. It has been a long time but years ago I used Naval Jelly. I googled it and got hits for several other products also. Evapo Rust is another good product.
Old May 21, 2024 | 04:53 PM
Art S
I had this product years ago, then I finally ran out of it and when I went to buy some more I couldn't find it anywhere, I thought the company went out of business. I finally found it again but it's under this company name. I wonder if Evapo Rust is the same thing?
Old May 21, 2024 | 04:55 PM
cdrod's Avatar
Rodney
I placed my deck lid upside down on some sawhorses and poured Ospho inside. I carefully propped and tilted the deck lid so the Ospho would soak into each of the 4 sides where the outer sheet metal is folded over the inner deck lid frame. I put blue painters tape over the emblem and lock holes to keep the Ospho from spilling out; it was very messy so say the least, but I was able to soak it on all four sides. Do this on some plastic sheet and don't spill any on a concrete driveway as it will etch the surface.
If you don't know, Ospho is a type of rust convertor that turns surface rust (ferric oxide, FeO2) into iron phosphate (FePO4) which is a hard coating that turns the rusty metal black. I followed up with some rattle can undercoating sprayed as best as I could get into those areas to help seal against future moisture.
Rodney
Old May 21, 2024 | 09:00 PM
I bought a new GM deck lid in the 80s and did similar to the above, but with a can of Rustoleum paint instead of ospho since it was pristine metal. I tilted the lid around so the Rustoleum flowed into the gaps in every seam.
Chuxter
Body work
Aug 15, 2023 09:14 AM
jmcghee
Nov 19, 2021 11:49 AM
dnmfranco
Nov 9, 2013 01:44 PM
lshlsh2
Body work
Mar 4, 2009 03:27 PM
