1964 jetstar 88 conv. floor pan?
Old Feb 20, 2017 | 10:48 AM
jetstar88convertwi's Avatar
Does anyone know if there is a large difference between the passenger rear floor pan from a 64 impala, and my Jetstar 88? It's my understanding that all the B body GMs were similar and the carpet is the same. I can modify it to fit if its close. Otherwise is there a supplier for new floor pans for my car?
Old Feb 21, 2017 | 05:42 AM
There isn't a supplier of B/C body Oldsmobile body panels that I know of. You will either have to find a donor car, rebuild the floor pan with sheet metal or adapt an Impala floor pan. I would go with option number 3 if you can't find a reasonable parts car.
Old Feb 21, 2017 | 09:27 AM
3 is what I am going to try.
Summit Racing sells floor pan sections that are suppose to fit 64 B body Chevys and Pontiacs. I am going to try to modify it to fit. I will update this when I try it. Thanks for the response.
Old Feb 21, 2017 | 10:37 AM
Let us know how it goes.
Old Mar 18, 2017 | 10:00 AM
Impala floor pan will work with help.
I was successful in using the Impala rear passenger floor pan. It took some extra cutting and bending but I was able to make it work. The biggest difference was in the back inside corner. But if you have enough good metal like I did you can cut it and lay it flat in that corner.
jstrits
Feb 7, 2016 11:33 AM
AzChevs
Oct 8, 2014 10:13 AM
tflem81
Jun 23, 2012 08:11 PM
Mr. Jetstar
May 16, 2010 08:13 PM
wim lesabre59
Apr 12, 2009 12:03 PM
