1964 Dynamic 88 holiday coupe Windshield trim removal
Hi!
I started removing the windshield trim of my 64:
1. removed wiper arms
2. removed screws from cowl vent panel
3. removed cowl vent panel
4. removed screws for lower trim LH and RH
5. removed lower trim LH and RH
till here it was easy going without any damage
But how is the windshield side trim attached?
Thank you for your help
The mouldings are held on by spring loaded clips.
If the rubber is hard from age, you may need to cut it with a boxcutter knife to access the clips.
Get a copy of the 1964 Oldsmobile Shop Manual.
1964 oldsmobile shop manual for sale | eBay
It explains the removal of this trim, plus so many more things you will need to know about this car.
