Lower Windshield Trim Finish - How To Get That "Fade"
Old Jun 4, 2014 | 02:11 PM
costpenn's Avatar
On my 70 442, the wide lower windshield trim that mounts to the lower cowl has no dents, but needs a little work to take out some minor scratches and I do not want to lose the "fade" effect of the shine decreasing as you go from the top of the trim to the bottom. Does anyone know what I'm talking about, and if so, how were you able to keep or reproduce this if the trim needed polishing?
Old Jun 4, 2014 | 03:27 PM
68442's Avatar
I have had a few NOS ones over the years and it is a polished piece. not like a mirror by any stretch but polished. no fade, Could the polish vary? Possibly
Old Jun 4, 2014 | 08:11 PM
costpenn's Avatar
It is more like two levels of finish now that I take a close look at it. See attached pic - below the contour line is not as finished as above.
Old Jun 5, 2014 | 05:37 AM
68442's Avatar
I see what you mean. How about this for an idea.
Polish the part to remove whatever you need to. Then a low PSI blast with a soft media like walnut shells to get your intended fade. ????
Old Jun 5, 2014 | 07:24 AM
mrolds69's Avatar
Right...that piece originally was more dull at the bottom. Definitely, you are right. That's how my 69 is. Maybe later they just polished the whole piece. Repros and polished pieces are not.
Old Aug 17, 2014 | 09:36 PM
jstrits's Avatar
practice on the back side with different grits of sandpaper and rub it in one precise direction. Try 400-800 grit to see what looks close
Oldssupreme
May 28, 2013 05:35 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
rlafash
Dec 8, 2010 05:24 PM
Garbled
Oct 27, 2010 05:54 AM
