Trunk Pan - South/Central Jersey
Hey Guys,
Need to replace the trunk sections of a 70' Cutlass Supreme. The inner wells are fine as the rust is strictly in the pan areas but bad from edge to edge. To give me some sort of planning as I have zero body shop contacts, anyone have a good shop in the south Jersey area? Also, anyone have an idea of what an affordable yet reputable shop would charge for this type of repair?
If you know any one that can weld this job is doable with zero body work skills a lot of members have done it buty guess is 10-20 hrs of work depending if you pulled out the gas tank or if they did I pulled my tank cut out the old and a friend welded it in all in less the 15 hrs and that included me cleaning up all edges and welds after
OldsManNJ
Nov 14, 2012 03:53 PM
84oldsDelta88
Mar 12, 2012 07:18 AM
