Vista Cruiser Tailgate: Lubes plus Mystery Part
Old Nov 12, 2023 | 01:10 PM
Robert Green's Avatar
Hi all, I am now replacing the window sash in the tailgate and have a couple of question you may be able to help with. As I have access to the regulator I may as well lube it but the world has moved on since the body manual recommended Fisk Bros 777 Lo Temp. What would you suggest - I think Sil-Glyde or similar might be appropriate? Also for hinges etc, would you recommend a white lithium spray? Also, along with the rust flakes, I found a mystery component in the bottom of the tailgate.It looks serious (pic attached) but I don't know what it is! Can anyone Help? Thanks, Robert Green
Old Nov 12, 2023 | 01:20 PM
I have a small can of Lubriplate brand white lithium grease in can that I've had forever for moving parts that I apply with an acid swabbing brush.
Old Nov 12, 2023 | 01:23 PM
^^x2^^ Exactly what I'd use and how I use it.
Old Nov 12, 2023 | 01:53 PM
4R5's Avatar
4R5
That square pad is probably the bumper stop for the window. There should be a round hole in the bottom of the tailgate where it presses into.
Old Nov 12, 2023 | 05:13 PM
VC455's Avatar
Barely Registered
Robert,
Here's one man's experience...
In 1983, my Vista Cruiser windows were operating slowly. The white lithium grease had hardened in the 13 years since the car was assembled, so I cleaned it off the sectors and applied a synthetic grease (then newly-developed by AMSOIL). I took the motors apart and used synthetic grease in them as well.
Forty years later, the synthetic grease is still working well enough that the speed of closing hasn't changed much, and the grease on the sectors was still fluid when the upholstery shop had the panels off five years ago.
Cheers,
Gary
Old Nov 13, 2023 | 03:41 AM
Oldsguy's Avatar
Past Administrator
Good luck with the install Robert.
Old Nov 13, 2023 | 01:07 PM
rocketraider's Avatar
Oldsdruid
A good quality white lithium grease will work fine, or a synthetic like Gary mentioned. SuperLube brand synthetic has worked well for me and Harbor Freight has it.
mathon
Vista Cruiser & Wagons
Nov 8, 2023 07:34 PM
jaunty75
Mar 23, 2023 06:01 AM
petercasper1969
Feb 19, 2022 12:03 PM
Greg Rogers
May 7, 2014 06:39 PM
197064buickspec
Sep 9, 2013 08:55 PM
