Push rod length
Old January 17th, 2015, 06:36 PM
bwheeler's Avatar
Push rod length
Help
I building a 455 for my 1972 Cutlass I have Edelbrock big block heads (PN 60519) with a Edelbrok Performer 2151 intake. The cam is a *****' Thumpr 287TH7 High Performance.The lifters are COMP Cams High Energy Hydraulic Lifters 852-16. Can someone help me find the correct push rod length? The lifters are COMP Cams High Energy Hydraulic Lifters 852-16.
bwheeler is offline
Old January 19th, 2015, 03:11 AM
Pewter442's Avatar
So what I recommend is calling the tech line at summit racing. They are very helpful. I called them with question about our 65 425 and they were able to help. Just me 2 cents.
Pewter442 is offline
Old January 19th, 2015, 04:04 AM
You need to buy a measuring pushrod from one of the usual suppliers (or make one, if you're so inclined) and measure the proper pushrod distance, then order the correct length pushrods.
MDchanic is offline
Old February 24th, 2015, 07:15 PM
68 D88's Avatar
On my procomp heads (edelbrock copies) with stock deck height and single steel shim head gaskets I used comp cams 7183-16 pushrods which are 9.800" length per edelbrocks head installation recommendations. They were a perfect fit.
68 D88 is offline
costpenn
Brakes/Hydraulic Systems
December 29th, 2012 02:53 PM
LX89mustang
September 27th, 2012 07:27 AM
ggriffin1960
February 5th, 2012 07:20 PM
ggriffin1960
January 31st, 2012 10:20 AM
defiant1
April 16th, 2011 11:07 AM
Quick Reply: Push rod length
