Push rod length
Push rod length
Help
I building a 455 for my 1972 Cutlass I have Edelbrock big block heads (PN 60519) with a Edelbrok Performer 2151 intake. The cam is a *****' Thumpr 287TH7 High Performance.The lifters are COMP Cams High Energy Hydraulic Lifters 852-16. Can someone help me find the correct push rod length? The lifters are COMP Cams High Energy Hydraulic Lifters 852-16.
You need to buy a measuring pushrod from one of the usual suppliers (or make one, if you're so inclined) and measure the proper pushrod distance, then order the correct length pushrods.
On my procomp heads (edelbrock copies) with stock deck height and single steel shim head gaskets I used comp cams 7183-16 pushrods which are 9.800" length per edelbrocks head installation recommendations. They were a perfect fit.
ggriffin1960
Jan 31, 2012 10:20 AM
