Help with piston indentification
Old Sep 20, 2014 | 03:18 PM
H8D-67's Avatar
I have a 425 BBO 1965 block. Just resealed the motor and put in a new cam and noticed the pistons are aftermarket. They have a stamp on the underside that say "901P OCT 93" I have tried to research online and cannot find out what pistons they are and was wondering if any of the long time Olds guys here might have a clue. Thanks!
Old Sep 22, 2014 | 09:16 PM
H8D-67's Avatar
Alright so removed my heads and no luck with part numbers but does anyone know if these look like low or high compression 425 pistons?
Old Sep 23, 2014 | 06:08 AM
Hawghead's Avatar
I'm gonna say that they are 10.25:1 pistons just based on the pointed notch. The lower compression pistons had a more rounded notch I believe.
Scott
Old Sep 23, 2014 | 06:32 AM
Oct 93 is obviously the casting or mold date, so these are aftermarket of some type. Since they are over 20 years old, it's likely that they are no longer in production, so an internet search may not turn up any info.
Old Sep 23, 2014 | 07:03 AM
72 w29 all green's Avatar
To my eyes, those dishes are way too deep to be "high compression".
Old Sep 23, 2014 | 08:52 AM
edzolz's Avatar
Measure the depth of the dish. It looks to be about 1/4 inch in the pics. If so, they are low compression. High compression will measure about .060 deep.
Old Sep 23, 2014 | 09:43 AM
Octania's Avatar
Are you sure it's not converted to a 455 with a cast crank?
Old Sep 23, 2014 | 10:39 AM
H8D-67's Avatar
Confirmed it's a 425 yestersay. Measured the stroke. Not the greatest pic. But when your 100% eye level with it the deck is just a hair under 4 or right on it basically.
Old Sep 23, 2014 | 10:46 AM
H8D-67's Avatar
From looking at some pictures of when I was measuring stroke from the center of the piston to the deck measures in at what looks to be 4 3/8" and from the flat edge is normal 425 stoke which is 3.975". Calculating the difference gives me a dish of about .40. I know it's not exact, basically eyeballing it for now. But sounds like it might be high comp
Old Sep 23, 2014 | 11:38 AM
H8D-67's Avatar
I forgot to mention compression check results before I opened the motor when a little below operating temp were at 165. And the head gasket that came off looked like a thicker felpro. Would it be safe to assume my cr ratio is prolly somewhere in the higher 9's?
Old Sep 23, 2014 | 03:45 PM
If it were me, while the engine is open I would measure the head combustion chamber volume, the piston dish volume, and the piston-to-deck clearance. Those numbers would allow determining the exact compression ratio, with no guessing.
Old Sep 23, 2014 | 05:32 PM
Octania's Avatar
http://www.ebay.com/itm/6-Inch-150mm...item27ec32e766
NAS Backyard
Jun 13, 2013 04:56 PM
JeremyTA
Apr 26, 2011 02:34 PM
Ranzan
Apr 19, 2011 06:33 AM
tim72
Drivetrain/Differentials
Mar 11, 2009 01:05 PM
