Helicoil or tap
Helicoil or tap
Hi Guys,
Putting the steering pump brackets back on my 68 400 I found the lower bolt hole stripped on the block. My question is should I fix it with a helicolil the same 7/16 size or re-tap it to a 1/2 thread?
Thanks,
Craig
Thanks,
Craig
I put 3 helicoils in a crankshaft on a BBC and ran it with a 4spd, for 13 years. Couple clutch changes, and flywheel resurface, and a couple trans never had a problem with the helicoils at all.
Moral of the story, helicoil= good stuff.
Awesome! been a few years since I used one.
Good to know, thanks!
We used helicoils on the 20mm Gatling guns because of the available locking feature... the pullout strength is higher than original provided there is enough "meat" on the part. Can't ask for much more demanding service!
Big dope!
So I went out looking for the correct Heli coil kit finally found it. When I went to install it I realized the bolt was actually a 7/16 not a 3/8 bolt! I didn't strip it after all. I guess it is still better to have a little egg on your face than have to go through the trouble of fixing it! Right? Oops!
Thanks for the discussion!
Craig
Craig
Craig
Craig
