Helicoil or tap
Old February 13th, 2014, 09:13 PM
442craig's Avatar
Helicoil or tap
Hi Guys,
Putting the steering pump brackets back on my 68 400 I found the lower bolt hole stripped on the block. My question is should I fix it with a helicolil the same 7/16 size or re-tap it to a 1/2 thread?
Thanks,
Craig
442craig is offline
Old February 13th, 2014, 09:18 PM
TripDeuces's Avatar
I'm gonna go heli-coil for $200 Alex
TripDeuces is offline
Old February 13th, 2014, 09:32 PM
442craig's Avatar
Is that a "Final Jeopardy" answer?
Thanks!
442craig is offline
Old February 13th, 2014, 09:45 PM
Nufo's Avatar
Talking
HELI - all your hardware stays as it was... that's my 2 cents on it
Nufo(Fred)
Nufo is offline
Old February 13th, 2014, 11:41 PM
Helicoil is the more elegant solution.
MDchanic is offline
Old February 13th, 2014, 11:48 PM
'87 Delta 88 Royale
rustyroger's Avatar
Another vote for helicoil.
It will be at least as strong and possibly stronger than the original thread.
But make sure you don't overtighten it!.
Roger.
rustyroger is offline
Old February 14th, 2014, 12:33 AM
nsnarsk65cutlass's Avatar
The answer is how do you repair stripped out threads? Agreed
nsnarsk65cutlass is offline
Old February 14th, 2014, 06:48 AM
442craig's Avatar
Heli-coil it is! Well just found out what I'm doing this weekend! Just need to find a kit now!
Thanks for the support!
Craig
442craig is offline
Old February 14th, 2014, 06:59 AM
1970supremevert's Avatar
advance auto, autozone or napa should have it on hand
1970supremevert is offline
Old February 14th, 2014, 07:09 AM
66luvr's Avatar
I put 3 helicoils in a crankshaft on a BBC and ran it with a 4spd, for 13 years. Couple clutch changes, and flywheel resurface, and a couple trans never had a problem with the helicoils at all.
Moral of the story, helicoil= good stuff.
66luvr is offline
Old February 14th, 2014, 07:53 AM
442craig's Avatar
Awesome! been a few years since I used one.
Good to know, thanks!
442craig is offline
Old February 14th, 2014, 02:02 PM
kitfoxdave's Avatar
We used helicoils on the 20mm Gatling guns because of the available locking feature... the pullout strength is higher than original provided there is enough "meat" on the part. Can't ask for much more demanding service!
kitfoxdave is offline
Old February 19th, 2014, 06:27 AM
Land Yacht Captain
66ninetyeightls's Avatar
If installed correctly Helicoils are stronger than the original threads.
66ninetyeightls is offline
Old February 19th, 2014, 06:40 AM
Good stuff Maynard, they last a long time. Follow the directions.
oldcutlass is offline
Old February 19th, 2014, 08:10 AM
442craig's Avatar
Big dope!
So I went out looking for the correct Heli coil kit finally found it. When I went to install it I realized the bolt was actually a 7/16 not a 3/8 bolt! I didn't strip it after all. I guess it is still better to have a little egg on your face than have to go through the trouble of fixing it! Right? Oops!
Thanks for the discussion!
Craig
442craig is offline
Old February 19th, 2014, 08:17 AM
Professur's Avatar
Craig
DoH!!!
Professur is offline
Old February 19th, 2014, 05:41 PM
Lady72nRob71's Avatar
I vote egg over work anytime!
Just glad you found out before to retapped it.
Lady72nRob71 is offline
Old February 19th, 2014, 06:01 PM
442craig's Avatar
It takes a big man to admit his mistakes! Right!
442craig is offline
Old February 20th, 2014, 04:01 PM
m371961's Avatar
Once I thought I was wrong but I was only mistaken!
m371961 is offline
Old February 21st, 2014, 02:22 AM
Killian_Mörder's Avatar
Getting the Heli-Coil set was no mistake, though. There's never anything wrong with getting tools
Killian_Mörder is offline
Old February 21st, 2014, 04:15 AM
Octania's Avatar
Geez guys
Jeopardy responses must be in the form of a question!
Octania is offline
63super88
September 17th, 2014 10:19 AM
justinj
May 12th, 2014 08:04 PM
1971viking
July 13th, 2012 10:05 AM
olds70supreme
July 24th, 2011 08:27 AM
Quick Reply: Helicoil or tap
