1959 394ci Edelbrock or Holley carb.
Old Jan 20, 2014 | 06:40 PM
5998DownUnder's Avatar
Hi all,
After spending $670 on the four barrel Rochester by a so called pro to fix, the carb still runs crappy. So I am really happy!
I took matters into my own hands. As I am a tappet head from way back, I just happened to find a brand spanking new Holley carb (600, vac secondary, man choke) in my shed and threw it on with an adaptor plate. And yes, this did fix the carb problem. No bogging down at all now.
I actually need that carb for my Chev so it cannot stay on the Olds.
I am moving away from Rochester as no-one seems to, or want to, touch them here. Reco's from the states including postage are the same as a new carb at the store here.
Question Is:
What would you guys/gals recommend for the Oldsmobile?
Input greatly appreciated.
John.
Edelbrock and why
or
Holley and why?
Old Jan 20, 2014 | 06:50 PM
1964super88's Avatar
On my 64, 394 i had an edelbrock 1406 600cfm on it and it ran great. But i had to manually shift it as the linkages to the slimjim trans. So i had a older mechanic rebuild the 4 gc, and it runs much better the edelbrock, more power mainly. But he really knew his stuff and adjusted it to my motor, all for a case a beer too. So if you can get all the linkages to work right i think either the holley or edelbrock would be fine.
Old Jan 23, 2014 | 04:10 PM
Finally got the Holley on, a bit of work and it runs o.k. Still goes through the gears without the mechanical gearbox linkage connected, just the throttle is connected. Not as 'gutsy' as the Rochester however will get me out of strife until my reco motor from the States arrives in a few months.
At least I can drive it around.
Old Jan 23, 2014 | 05:10 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The new Street Demon carb is an improved version, all new castings carb. It will fit spread and square bore intakes. The only problem mentioned above is hooking up your shift rod.
Old Jan 28, 2014 | 03:42 AM
Street Demon, nice looking carb, was looking at that for my van that has a Chev in it a while back.
That could work.
Old Jan 28, 2014 | 04:18 AM
cutlassefi's Avatar
QF 750 Slayer. Cheap, good and very tunable.
Old Jan 28, 2014 | 04:25 AM
Thank you,
did not think of this one, I will check it out now.
John.
Old Feb 7, 2014 | 12:16 AM
lazy394's Avatar
how I would love a 3 x 2 setup !
I believe the linkage setup to the gear box is critical, so I would need to retain most of it.
Old Feb 7, 2014 | 01:25 AM
nsnarsk65cutlass's Avatar
The Edelbrock AKA carter afb is the least intrusive for 4gc replacement .Not a Holley fan..
Old Feb 7, 2014 | 07:50 AM
Like the others have said, the shift linkage is a critical component to your choice.
Old Feb 7, 2014 | 12:03 PM
Can someone put a photo up of the shift linkage So I know what that is?
Old Feb 10, 2014 | 09:17 PM
lazy394's Avatar
The shifter linkage is the one with the 2 adjusters (right hand side). I believe the gearshift is based on throttle position hence the 2 adjusters and centre pivot.
Kaline
Apr 18, 2022 03:35 PM
OldsManNJ
May 23, 2012 08:20 AM
gringocordoba
Feb 3, 2011 10:18 AM
sssingo
Nov 12, 2008 09:25 PM
Kaline
Mar 23, 2008 06:53 AM
