455 engine id
Old Nov 28, 2013 | 09:21 AM
diesel olds's Avatar
455 engine id
I cant figure out what year my block is or what it was in to start with was told it started life as a marine engine. the engine is a 396021F block but the pad on the left side of the block reads L1E on top 0705 below it and to the right inbetween is "S" anyone got any ideas
Old Nov 28, 2013 | 09:26 AM
oldstata's Avatar
Justin
the L indicates a marine engine if memory serves me correctly
taken from olds faq
For marine engines, there is a number that begins with an "L". This strange "VIN derivative" (or engine unit number) number starting with L denotes a marine motor. This may appear something like "L8E00", where L = Marine or irrigation engine, 8 = 1968 model year, and E00 = engine serial number (although there are usually more digits in the serial number). There might also be a drill spot on the pad.
also I think that the "L" is marine irrigation and motorhome as well not positive tho
Old Nov 28, 2013 | 09:54 AM
boy you guys are great ask a question, and a good answer within minutes thanks
805cut
May 3, 2012 08:11 PM
Olds luvr
Mar 17, 2010 06:57 PM
njot33
Sep 25, 2009 09:07 AM
pinky
Oct 1, 2007 11:24 AM
