Water outlet question
Old September 15th, 2013, 02:47 AM
louie's Avatar
I'm not running a heater core. Do you just cap the water pump outlet and the intake inlet thats in the passenger side rear of the intake? I see some run lines from the back of the engine to the thermostat housing
louie is offline
Old September 15th, 2013, 05:10 AM
Yup.
MDchanic is offline
Old September 15th, 2013, 05:17 AM
ziff396's Avatar
Yes. Just cap the water pump and intake using pipe plugs. The rubber caps that are sold may not last long. Some will say that running a hose from the water pump to the rear of the intake will give better circulation and cooling. I have not noticed a difference either way.
ziff396 is offline
Old September 15th, 2013, 07:43 AM
Just to confirm that there is no need to run a hose from front to back, factory heater-delete cars did not use a hose. The ports were simply plugged.
joe_padavano is offline
jensenracing77
February 11th, 2014 03:44 PM
67 Cutlass Freak
September 19th, 2013 08:56 PM
kips70cutty
July 23rd, 2011 10:38 AM
Mattman1961
September 22nd, 2007 08:32 PM
155thINF
August 25th, 2006 05:30 PM
Quick Reply: Water outlet question
