65 442 starving for fuel
Old Aug 17, 2013 | 08:02 AM
jimmies442's Avatar
I rebuilt the enigne with original 4gc carb, new fuel pump, pulled tank and cleaned it, and she starts and runs like a champ. After she gets warm it seems to quit pumping fuel as I notice the fuel filter goes empty.....even at idle it wont fill up This only does it after 10 mintes of warmup time. Is that what happens with a faulty fuel pump? I'm changing it out tomorrow but maybe someone bought a bad pump outta the box too or I have other issues. Fuel lines new btw except for the steel one along frame, but it cant be clogged because at startup i have lots of fuel
Old Aug 17, 2013 | 08:31 AM
I would not assume that the fuel pump is not working properly just looking through the clear fuel filter. What I would do is throw a fuel pressure gauge on t and see what it's doing. Does the car stall or fall on it's face during a long wot run?
Old Aug 17, 2013 | 08:39 AM
Do you have any actual running problems, or do you just not like the looks of the fuel filter?
Old Aug 17, 2013 | 08:51 AM
jimmies442's Avatar
car starts right up, fuel filter fills up and I can go about 5 miles or til its warm/hot, then yes it starts spittin and jerking hard
Old Aug 17, 2013 | 08:57 AM
Double check all your fuel lines, if all your lines look good then a new fuel pump is probably the likely culprit.
Old Aug 17, 2013 | 09:04 AM
jimmies442's Avatar
Yea I'll find out tomorrow and post it. Someone said the diaphram might have a tear in it. Got me a carter pump commin in.......no more shucks orielly in a box crap I shuda known better
Old Aug 17, 2013 | 11:14 AM
Ozzie's Avatar
Run a test
A pressure and volume test on the fuel pump should tell you if there is a problem with it or anything further back in the line or tank.
Old Aug 17, 2013 | 11:23 AM
nsnarsk65cutlass's Avatar
Put a vacuum gauge on the suction side of the pump,also you may have rust holes in the frame line.
Old Aug 17, 2013 | 03:20 PM
jag1886's Avatar
Check your gas cap also, should be vented if not it can cause a vacuum in the tank stopping the fuel from coming out.
dfire25
Jun 28, 2016 01:37 PM
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
Fitti Six
Mar 23, 2014 10:17 AM
squirell
Apr 13, 2013 06:46 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
