425 toro heads off
Old August 10th, 2013, 08:33 AM
lowkey235's Avatar
425 toro heads off
I pulled the heads pistons look fine one has a DD stamped or engraved I don't know what it means if anything...any ideas? Will post pic when I can I'm on my phone .
lowkey235 is offline
Old August 10th, 2013, 09:27 AM
Octania's Avatar
I hope there is a D stamped into the deck surface next to that bore.
That means they fell asleep at the hone machine and honed that bore out to the largest still-std size, coded "D" and so they put a D [or DD in this case] piston in it to match. Can you find all the cylinders' size code letters?
Octania is offline
Old August 10th, 2013, 10:06 AM
lowkey235's Avatar
There is an x on the cylinder head under the rockers in that position.I'm unsure of cylinder size code letters...I couldn't find them in my shop manual
Old August 10th, 2013, 10:19 AM
lowkey235's Avatar
There is C in the bore identification
Old August 10th, 2013, 10:48 AM
Octania's Avatar
Here's some typical stamps:
It's a factory exact size tolerance stamp. Means little at this point.
Octania is offline
Old August 10th, 2013, 10:52 AM
lowkey235's Avatar
Does the c mean the same thing as the dd?
Old August 10th, 2013, 11:10 AM
lowkey235's Avatar
I had extremely low compression on that cylinder
Old August 11th, 2013, 02:29 PM
lowkey235's Avatar
I found a chart for an early 70s 455 with block and piston codes..c block and d piston keep me with standard rings, if I am correct that the stroke is the difference between 425 and 455 blocks
Old August 11th, 2013, 03:01 PM
Octania's Avatar
Correct.
A, B, C, D are all subtle variations (like a few TEN-Thousandths of an inch) on the std bore size, like [but these figures are picked out of the air, not the manual]:
A = 4.1250-4.1254
B = 4.1255-4.1259
etc.
ABOVE FIGURES ARE GUESSES, not real factory numbers! From my feeble memory.... Check the Chassis Service Manuals for real exact numbers. Perhaps part number manuals.
Yes, the stroke [Crank, rods, pistons] is the difference between the 425 and the 455.
Octania is offline
Old August 11th, 2013, 03:17 PM
lowkey235's Avatar
Thanks for all your help
Old August 12th, 2013, 06:11 AM
edzolz's Avatar
Remember, you can put the entire rotating assembly from either in either block. IE, put the assembly from a 455 in a 425 block or the assembly from a 425 in a 455 block. The cubic inches match the rotating assembly.
edzolz is online now
vistacruiser1971
December 27th, 2012 07:35 AM
geckonz08
July 25th, 2008 12:44 PM
geckonz08
June 5th, 2008 11:18 AM
DJMatthews
December 5th, 2006 01:28 PM
<Fuelie 425>
July 15th, 2004 04:29 AM
Quick Reply: 425 toro heads off
