1970 olds 442 engine rebuild question
Old Aug 1, 2013 | 10:10 AM
cdoering's Avatar
I have a 1970 Olds 442 W30 engine to rebuild. I have all the other correct W30 parts (carb, distrib, intake & exhaust manifold). I want to keep as much original as possible. other info - I have E heads now but looking for F heads. (E heads were redone to accept regular unleaded gas)
Question - One of the pistons will need replaced. Engine turns freely.
What pistons should I use as well as rods / bearings?
Thoughts on boring block?
Where should I get parts for engine rebuild?
Anything I'm missing or suggestions
Chris in St.Louis 314-495-1700
Old Aug 1, 2013 | 11:47 AM
stevengerard's Avatar
hopefully the engine folks will chime in but depends on what you want from the engine. I kept mine as close to stock as possible, went with forged pistons just because and got a modern grind camshaft that added a bit more pep but did not go overboard. My thoughts are if the engine doesn't need to be bored don't do it but most likely it will so do as little as you can. - mine was bored .020 over IIRC
I have read in many places that folks say do not bother getting hardened valve seats on Old's heads but again see who chimes in that knows way more than I do about engines..
Old Aug 12, 2013 | 08:16 AM
cdoering's Avatar
What kind of gas are you using with your car.
Charles Ludwick
Dec 27, 2011 03:17 PM
Jeff70442
Oct 5, 2011 04:22 PM
Hark442
Feb 25, 2010 01:01 PM
B-Mann
May 19, 2009 10:47 PM
ragtop442
Oct 22, 2008 06:16 PM
