Oil pressure gauge for the 394
Old Jun 19, 2013 | 08:12 AM
394 Skyrocket's Avatar
I have the gauge but haven't crawled under the engine to look for where it will hook up to...where will I find the connection for it? This is the mechanical style gauge vs the electrical.
Old Jun 19, 2013 | 09:21 AM
Oldsmaniac's Avatar
If memory serves me on mine there was a fitting on the screw on type oil filter housing assembly. I do not know if this holds true for the cannister type filter.
Old Jun 19, 2013 | 12:15 PM
I will check that out and let you know. I appreciate the input!
Old Jun 19, 2013 | 08:15 PM
rocketraider's Avatar
Oldsdruid
Maniac is right. Oil senders for these engines are on the oil filter adapter housing. RH side of engine underneath the car. Make sure you put a vibration loop in the tubing and run it thru a grommet where it passes thru the firewall. Copper tubing preferred over the plastic junk that comes with most gauges.
Old Jun 19, 2013 | 10:19 PM
I agree, I had a gauge on my CJ5 Jeep and it was the plastic tubing at first and after it sprayed all over me I switched it to copper. I found fair prices on the tubing on eBay unless anyone else has a better suggestion. $15.95 shipped was about the best I found.
Del70
Aug 23, 2017 03:59 AM
72OldsRocketMan
Feb 27, 2014 08:37 AM
foreverolds
Dec 1, 2012 07:07 PM
Del70
Sep 11, 2012 06:45 AM
tecar442
Jun 14, 2009 06:08 PM
