455 overheating
Can a 455 have a propensity to overheat on the highway................. especially on hot days ................and contaminate the coolant if the driver side front bottom short head bolt is not torqued to 85 ft.lbs? Say it was only at 25-30 foot pounds?
joepenoso
PS I was chasing an overheating problem at highway speeds and hope this was the cause. Sure hate to go through all this and find out it's still there
joepenoso
The concern is contaminated coolant + the overheat. What is the coolant contaminated with? Exhaust or oil? Is there any contamination in your oil? What does the spark plug look like for that cylinder, and bank?
There are chemical test kit you can get from napa think like fifty bucks to test coolant .
How old is your radator it could have restriction from build up . Also what work has the motor had is the rad big enough to cool properly I would rule out clutch fan most of the time those cause over heating at idle but cool while driving , but never say never
I tried to keep the story short.....................the heads were marked "H" but when checking casting numbers they were really "J". The cable was placed there to cover up the shoddy reproduced fraud numbers.
I replaced the J's with exhaust crossover filled, pocket ported, exhaust dividers separated and equalized at the exit "C" heads. Looking at the (Steel shim) head gaskets I found nothing wrong............... and replacing ( New 40 year old OEM steel shim) and the aftermarket 5 blade cast iron water pump with a 7 blade aluminum German (GHB)owned Japanese manufactured water pump and Chinese aluminum radiator I never found anything unusual.
The overheating was the reason I started to take it apart and I am now replacing the stock rockers with Harland Sharp#5001 rollers. it's a MAW since I got a package deal with a lot of aftermarket parts included with the heads. It's a wonder if it's got any American parts in it. The new bumpers on it say "Made in Taiwan". I have 3 young kids under 9 years old and an angry wife so I can't make progress as fast as some others on here
joepenoso
joepenoso
I have a 66 Cutlass with a 330. I had that problem and the reason was if you replace a standard water pump with a HD the pulleys need to be changed too. Using the correct pulleys give you 100 RPM more at the pump which the HD pump needs to properly move the coolant. That was what fixed my car.
jkoester122
Dec 6, 2010 09:02 PM
