455 overheating
Old Jun 12, 2013 | 08:33 PM
joepenoso's Avatar
Question 455 overheating
Can a 455 have a propensity to overheat on the highway................. especially on hot days ................and contaminate the coolant if the driver side front bottom short head bolt is not torqued to 85 ft.lbs? Say it was only at 25-30 foot pounds?
joepenoso
PS I was chasing an overheating problem at highway speeds and hope this was the cause. Sure hate to go through all this and find out it's still there
Old Jun 13, 2013 | 06:17 AM
The concern is contaminated coolant + the overheat. What is the coolant contaminated with? Exhaust or oil? Is there any contamination in your oil? What does the spark plug look like for that cylinder, and bank?
Old Jun 13, 2013 | 07:12 AM
TripDeuces's Avatar
If I'm not mistaken the head bolts don't go into the coolant passages. If that's your question.
Of course having it at 25-30 pounds might cause the head gasket to leak in that area.
Old Jun 13, 2013 | 10:49 AM
joepenoso's Avatar
The head gasket shows no signs of blowing to me. The coolant contamination doesn't seem like oil.
joepenoso
Old Jun 13, 2013 | 11:08 AM
What does it seem like?
Old Jun 13, 2013 | 11:20 AM
oldstata's Avatar
Justin
There are chemical test kit you can get from napa think like fifty bucks to test coolant .
How old is your radator it could have restriction from build up . Also what work has the motor had is the rad big enough to cool properly I would rule out clutch fan most of the time those cause over heating at idle but cool while driving , but never say never
Old Jun 13, 2013 | 11:41 AM
1970-W30's Avatar
I'm wondering why you have (only) one head bolt torqued to 25 -30 lb/ft????
Old Jun 14, 2013 | 05:27 AM
joepenoso's Avatar
Previous owner loosened the short front head bolt to attach the Ground from the battery. not having owned Olds before I assumed that was normal
joepenoso
Old Jun 14, 2013 | 07:13 AM
TripDeuces's Avatar
What's normal is to bolt the ground cable to the front of the head where there is a 3/8 x 16 bolt hole. No need to use the head bolt.
Old Jun 14, 2013 | 08:12 AM
joepenoso's Avatar
Red face
I tried to keep the story short.....................the heads were marked "H" but when checking casting numbers they were really "J". The cable was placed there to cover up the shoddy reproduced fraud numbers.
I replaced the J's with exhaust crossover filled, pocket ported, exhaust dividers separated and equalized at the exit "C" heads. Looking at the (Steel shim) head gaskets I found nothing wrong............... and replacing ( New 40 year old OEM steel shim) and the aftermarket 5 blade cast iron water pump with a 7 blade aluminum German (GHB)owned Japanese manufactured water pump and Chinese aluminum radiator I never found anything unusual.
The overheating was the reason I started to take it apart and I am now replacing the stock rockers with Harland Sharp#5001 rollers. it's a MAW since I got a package deal with a lot of aftermarket parts included with the heads. It's a wonder if it's got any American parts in it. The new bumpers on it say "Made in Taiwan". I have 3 young kids under 9 years old and an angry wife so I can't make progress as fast as some others on here
joepenoso
Old Jun 16, 2013 | 05:27 PM
SIPLOWGUY's Avatar
I have a 66 Cutlass with a 330. I had that problem and the reason was if you replace a standard water pump with a HD the pulleys need to be changed too. Using the correct pulleys give you 100 RPM more at the pump which the HD pump needs to properly move the coolant. That was what fixed my car.
Old Jun 17, 2013 | 11:38 AM
joepenoso's Avatar
Question
Both upper and lower pulleys have 3 rows and the water pump thickness for both is about 6 inch so they are both the same
joepenoso
gibbo69olds
Nov 21, 2012 09:30 PM
jerseymike
Apr 12, 2012 06:37 AM
jkoester122
Dec 6, 2010 09:02 PM
1964F85
Sep 30, 2010 09:20 AM
skibone
Jan 13, 2007 07:29 PM
