Evans Waterless Coolant
Old Jun 6, 2013 | 08:04 PM
Don Roberto's Avatar
Hi! Has anybody tried Evans Waterless Coolant? Jay Lenons uses it in his cars and recommend it for classic cars. It will not correct cooling problems but I feel that for slight idling overheating it would be an option.
http://www.evanscooling.com/
Old Jun 6, 2013 | 08:19 PM
Although it has a higher boiling point is higher, the temp is still going to effect your engine and trans. It looks to be a good product but it will not solve an over temp problem.
Old Jun 6, 2013 | 08:23 PM
Yeah. It seems that any overheating problem should be resolved before using this product.
Old Jun 7, 2013 | 08:19 AM
rustyroger's Avatar
'87 Delta 88 Royale
If you fix your idling overheating problem properly regular 50% antifreeze mix should be all you need.
Otherwise any cooling fixes will be band aid solutions, give us more information about your car and we can help resolve any issues you have.
Roger.
Old Jun 17, 2013 | 05:10 PM
Roger sorry for the delay in responding. I fixed the overheating issue. I had a bad fan clutch. But the Evans also prevent the constant change of antifreeze and since it does not have water, it also prevents engine corrosion. I don't know, I might like to try it at some point. I just added new antifreeze and planning to change it next year. I'll consider it then.
wcourt3010
Nov 14, 2014 10:34 PM
oldsonharmont
May 6, 2014 09:13 AM
dc2x4drvr
Mar 21, 2014 07:20 PM
ztim
Dec 22, 2006 10:20 PM
Diabolus
Jul 23, 2004 04:35 AM
