pushrods
Old Jun 17, 2013 | 08:31 PM
steverw's Avatar
pushrods
Hi all, im building a 67 E block 400. The heads were milled approx .007, the block was decked also approx. .007. My new cam is 504 lift if im remembering correctly. I have Comp adjustable roller tip rockers.
Question: Can i use stock length 455 pushrods as no one seems to sell the 400 pushrods. I do have my old pushrods which are in good shape, i was just thinking a better quality pushrod might be better.
Any thoughts on this?
Steve
Old Jun 18, 2013 | 05:45 AM
cutlassefi's Avatar
Hey Steve,
The Comp rocker setup requires hardened pushrods, stockers won't work.
You'll need to measure for the correct length. Even the ones that come in their kit are normally wrong.
Old Jun 18, 2013 | 09:22 AM
steverw's Avatar
Thanks Mark, infact the ones that cam with the kit were i think .001 longer than the stock 455 pushrod. Maybe it was .010 longer i dont remember now, and they were welded ball tips. I read on another post somewhere in here not to use welded ball p-rods. I think the stock 400 pushrods are 9.42? or somewhere in that range. I have always used stock length in SBC motors with high lift cams, but i realize this is not a SBC. However with adjustable rockers i guess there is some play, but again as you said ill measure first
Thanks again
Steve
Old Jun 18, 2013 | 10:17 AM
chadman's Avatar
Here is an article worth reading. It is however more important to achieve the shortest travel of the roller tip across the valve stem than having it centered.
http://www.carcraft.com/techarticles...h/viewall.html
tinner
Mar 24, 2011 03:44 PM
1FSTLS1
Feb 3, 2011 03:52 PM
360scamp
Oct 21, 2010 09:58 PM
dman0712
Jun 1, 2010 07:02 PM
rtpassini
Dec 24, 2009 07:51 AM
