Help ID this engle cam
I picked up an 455 Olds motor.
There is an engle hyd flat tappet cam in it. The end is stamped engle and lw10 lw 11 and 80. I cant find any info on a cam like this I tried a couple searches and the engle website without any luck
I attached a few pics
thanks for any help
thanks for any help
Call or e-mail Mark @ Engle Cams:
http://www.englecams.com/contact.php
Good call copper thanks
they got right back to me and it falls right between the 2722h and 2725h listed above
heres what they said;
Valve lift; .518" int , .237 exh
Cam lift; 324"
Duration @.050 244°
lobe center 108°
next question is that too much cam for a stock valve train ?
Cam lift; 324"
Duration @.050 244°
lobe center 108°
I have run bigger cams with stock valve train. You will need good springs and 10 to 1 pistons would be preferred. An auto trans car should have a higher stall torque converter. A gear out back of at least 373- 390 would be good.
507OLDS
Nov 12, 2012 06:36 AM
