Help ID this engle cam
Old Oct 25, 2012 | 04:42 PM
RetroRanger's Avatar
72 Olds CS
I picked up an 455 Olds motor.
There is an engle hyd flat tappet cam in it. The end is stamped engle and lw10 lw 11 and 80. I cant find any info on a cam like this I tried a couple searches and the engle website without any luck
I attached a few pics
thanks for any help
Old Oct 25, 2012 | 05:33 PM
72 Olds CS
Originally Posted by coldwar
Are you certain it is a hydraulic? CW
To be honest i dont know jack about cams and only a bit more about engines. The engine had hydraulic lifters in it so I assume its a hyd cam ?
I will try to measure it as you say and post what I get for numbers here tomorrow
Old Oct 25, 2012 | 06:32 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Call or e-mail Mark @ Engle Cams:
http://www.englecams.com/contact.php
Old Oct 26, 2012 | 03:12 PM
72 Olds CS
Good call copper thanks
they got right back to me and it falls right between the 2722h and 2725h listed above
heres what they said;
Valve lift; .518" int , .237 exh
Cam lift; 324"
Duration @.050 244°
lobe center 108°
next question is that too much cam for a stock valve train ?
Old Oct 26, 2012 | 07:06 PM
Oldsmaniac's Avatar
I have run bigger cams with stock valve train. You will need good springs and 10 to 1 pistons would be preferred. An auto trans car should have a higher stall torque converter. A gear out back of at least 373- 390 would be good.
vette442
Jul 13, 2013 07:32 AM
p518
Mar 16, 2013 06:16 AM
507OLDS
Nov 12, 2012 06:36 AM
oldzy
Jun 1, 2011 05:02 PM
Daverd
Mar 20, 2011 03:12 PM
