Exhaust gasket difficulties
Old Sep 23, 2012 | 11:16 PM
delta88_frankfurt's Avatar
Hi everybody,
I need to exchange my Exhaust Pipe Flange Gaskets.
Every shop and online catalogue offers one size, the 2 1/8" version.
But my car (1966 Delta 88, 425cui) has two sizes.
the crossover pipe gaskets are smaller than the one that connects the muffler pipe. I think 2 1/8" only fits the larger one.
Can someone tell me what size I need for the two connections of the crossover pipe?
Old Sep 24, 2012 | 04:18 AM
I am not specifically familar with the '66, but are you sure that it has flange gaskets?
All of the later ones have gasketless flanges.
Old Sep 24, 2012 | 05:37 AM
Oldsmaniac's Avatar
If memory serves me right, on a stock single exhaust car the crossover pipe does not use gaskets. The pipe ends are flared and the manifold beveled and no gasket is used. There is a gasket on the exit pipe at rear of rt side manifold.
Old Sep 24, 2012 | 06:59 AM
Correct. There are no factory gaskets between the heads and the manifolds nor between the manifolds and the pipes. The manifolds have a male tapered flange and the pipes have a matching female taper. There is no provision for installing a gasket. If there is a leak, either the metal is damaged (usually rust pitting) or there is debris preventing a good metal-to-metal seal.
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
