HEI - red w/ black stripe to batt?
Old May 1, 2012 | 01:01 PM
zodiacblueS's Avatar
deleted - found answer elsewhere - blue to batt
Old May 1, 2012 | 05:47 PM
BILL DEMMER's Avatar
Just the facts...
IGN switched power, not battery.
bill
Old May 1, 2012 | 06:27 PM
Yeah.
If it's connected to the battery, the engine will never turn off .
Old May 2, 2012 | 08:55 AM
Now you guys are freaking me out. Attached is a reference pic showing the original setup w/ blue wire going to the batt side (right), and the red w/stripe going to the tach side (left). There is no IGN stamped, molded or labeled on either HEI. Look through the dust and grease and you can see the original setup there in the back. That's how I've done the replacement. After 6 months without running, when I start it, I definitely want to be able to shut it off.
Old May 2, 2012 | 10:24 AM
The wire from the IGN terminal of the ignition switch goes to the BAT terminal of the HEI.
Now that you mention it, I guess it IS sort of confusing, since everywhere else in the car, BAT means unswitched battery power.
Your connections look right to me, and those plugs only fit one way anyway, I believe.
Old May 4, 2012 | 09:41 AM
Just the facts...
thx for the pics, they really clear things up! i agree with MD, it looks correct. my only concern would be the gauge of the blue wire-it looks a little thin. the factory generally used a 12-gauge wire(i have seen where they used 10-gauge) to prevent misfire at high speed issues. it isn't about the average power draw, it's about the instantaneous power in-rush, or impedance. when the module switches on, you want the power there NOW to quickly saturate the primary field windings.
bill
firefrost gold
Sep 20, 2014 06:33 AM
joepenoso
Jun 4, 2014 01:56 PM
The_Avaricious88
Aug 10, 2011 03:40 PM
69OldsCutlassS
Aug 30, 2009 06:04 AM
Gaz Hog
Mar 22, 2009 03:39 PM
