Edelbrock Performer and HEI
Old Jan 15, 2012 | 07:15 AM
mdd71's Avatar
Running a 455 in my 74 Cutlass with the Edelbrock Performer. I would like to convert over to HEI but I hear the vac advance on the HEI interferes with the intake making timing adjustments an issue. True? Maybe Pertronix is the way to go?
Old Jan 15, 2012 | 08:10 AM
A HEI distributor fits fine. No clearance issues at all.
Old Jan 16, 2012 | 09:06 AM
GTI_Guru's Avatar
Certifiable car addict...
I dropped an HEI into my '66 425, and it had a slight clearance issue with the intake, but it was easily enough to remedy by rotating the distributor a bit further and then offsetting the plug wires either 1 or 2 spaces to put them back into the right spot for correct timing.
From what I remember, the vac advance wasn't the issue, it was one of the bosses for the cap hold down, or the plastic cap itself that interfered with the intake, but other than that, it worked beautifully.
joepenoso
Jun 4, 2014 01:56 PM
69CutlassAlex
Jul 30, 2013 08:18 AM
olds 307 and 403
Jan 11, 2012 03:39 PM
70Cutlass_408
Jun 24, 2011 07:55 AM
