which is the better (leakproof )thermostat stock-housing
I have a leaky chrome neck from Taiwan, wanted to swap in stock-cast or alum. one but not sure which one will better if use with Performer manifold.
A few sources would be great
thanks
thanks
http://www.robbmcperformance.com/pro...stat_olds.html Best there is for sealing it up
Looks about like this on an engine:
For what it's worth, the aluminum ones are cast, too.
I think that the main reason the factory switched from aluminum to iron was to switch to the bent tube with straight hose instead of the pre-formed J-hose. But it's generally accepted that the iron housing seal better, too. Then again, an iron housing might suffer galvanic corrosion with a Performer manifold.
Regardless of which housing you use, make sure the two sealing surfaces are flat.
I threw away the chrome piece of junk that came with the car. I cleaned up the original and stripped it bare. I used a parts store gasket and a little gasket sealer. It hasn’t leaked for about 8 years so far.
I've dealt with a lot of chrome thermostat housing whether they made from Taiwan or other countries, they always leak. No matter how much silicone i use or double gasket, etc...they've always leak. So now i switch to a cast iron type and it hasnt leaked yet.
