GM discontinuing BB oil indicator tube
Old Sep 9, 2011 | 12:13 PM
frankr442's Avatar
Did a stocking inquiry on GM's website when I reordered my dipstick tube and noticed that it was tagged "DISCON". THey still show stock in Willow Run MI, but when that's gone, that's it. GM # 401357 fits 400 and 455 A-body from 68-72, maybe more but my olds catalog is at home and I work at a Chevy dealership. P.S. Don't order stick # 419242. Even though it's the original #, they changed the handle to a yellow plastic T-style. (this breaks what used to be a rule with GM, any change=new #) So if you think you'll need one, get one now before they're gone.
Old Sep 9, 2011 | 10:35 PM
svnt442's Avatar
What is the part number?
Old Sep 10, 2011 | 06:59 PM
I'm amazed it was still available for this long. After all, it's only been THIRTY FIVE YEARS since the last BBO was built!
Old Sep 10, 2011 | 10:26 PM
svnt442's Avatar
Duh. Thanks Joe. I must have been more tired than I thought when I posted that.
Old Sep 11, 2011 | 05:56 PM
Bill in NC's Avatar
Do you guys know if they will work with headers? Or am I stuck with this lame cheesy chrome dipstick?
Old Sep 12, 2011 | 05:52 AM
frankr442's Avatar
401357 tube
That tube will "work" with headers, but since it's designed to lay right against the head , there will be some tension depending on the thickness of the header flange. I had one with my headers but I had to get rude with it when I swapped them for manifolds.
Old Sep 12, 2011 | 09:04 AM
Chesrown 67 OAI's Avatar
Ya gotta "massage it" (translated "bend it") to where it works good with your headers. It is MUCH easier to install with headers if you cut about 2" of unnecessary length from the BOTTOM of the tube ( that part that sticks down into the pan). Makes it MUCH easier to get it started into the hole in the block!!!
Old Sep 12, 2011 | 12:05 PM
svnt442's Avatar
Well I just talked to the dealer across from my work and he ordered me up a few. He also said they come in pairs for some reason so I will have some spares.
Old Sep 12, 2011 | 12:29 PM
stetzie's Avatar
stetzie
GM # 401357 Is it the same # for full size cas.
I have a '71 Royale convertible.
Stetzie
Old Sep 20, 2011 | 04:02 PM
Funkwagon455's Avatar
I finally got confirmation that my stash of fill tubes is enroute (6). I got 'em through GMPartsdirect.com, less than $60 shipped to my door.. If anyone may be interested in the online time saving route.
dingusboy
Mar 8, 2014 07:09 AM
1k442
Feb 6, 2013 02:16 AM
oldspackrat
Dec 6, 2012 02:48 AM
1k442
Sep 17, 2012 06:02 PM
