which is the better (leakproof )thermostat stock-housing
Old Sep 13, 2011 | 11:47 AM
STLCRZY's Avatar
I have a leaky chrome neck from Taiwan, wanted to swap in stock-cast or alum. one but not sure which one will better if use with Performer manifold.
A few sources would be great
thanks
Old Sep 13, 2011 | 12:13 PM
I've never been a fan of the cheapie chrome ones. I have not tried one of the "o" ring types, maybe someone can chime in here! I've had good luck with the stock-cast!!!
Old Sep 13, 2011 | 12:42 PM
ah64pilot's Avatar
http://www.robbmcperformance.com/pro...stat_olds.html Best there is for sealing it up Looks about like this on an engine:
Old Sep 13, 2011 | 12:46 PM
Tony72Cutlass'S''s Avatar
I've got an original one on my performer manifold works great and looks awesome painted gold.
Old Sep 13, 2011 | 01:19 PM
STLCRZY's Avatar
I know it and i´m sure it seals perfect...but $ uff!
Old Sep 13, 2011 | 01:20 PM
STLCRZY's Avatar
Original is the cast one?
Old Sep 13, 2011 | 02:22 PM
BlackGold's Avatar
For what it's worth, the aluminum ones are cast, too.
I think that the main reason the factory switched from aluminum to iron was to switch to the bent tube with straight hose instead of the pre-formed J-hose. But it's generally accepted that the iron housing seal better, too. Then again, an iron housing might suffer galvanic corrosion with a Performer manifold.
Regardless of which housing you use, make sure the two sealing surfaces are flat.
Old Sep 14, 2011 | 11:31 AM
STLCRZY's Avatar
thanks
Old Sep 15, 2011 | 04:44 AM
Destructor's Avatar
I threw away the chrome piece of junk that came with the car. I cleaned up the original and stripped it bare. I used a parts store gasket and a little gasket sealer. It hasn’t leaked for about 8 years so far.
Old Sep 15, 2011 | 04:03 PM
ELY442's Avatar
I've dealt with a lot of chrome thermostat housing whether they made from Taiwan or other countries, they always leak. No matter how much silicone i use or double gasket, etc...they've always leak. So now i switch to a cast iron type and it hasnt leaked yet.
Old Sep 19, 2011 | 05:17 PM
bajaman73's Avatar
I have a cheap Taiwan chrome jobbie that don't leak. But the PO put GOBBS of sealer on it. Looks pretty disgusting and will be changed soon.
Old Sep 20, 2011 | 04:06 AM
442_Mustang's Avatar
Yep... 100.00 is kinda spendy... My cheapo chrome one is a leaker too... I will have to show it some love this fall...
coldfire
Aurora
24
Mar 31, 2012 06:28 PM
citcapp
Oct 1, 2010 11:23 AM
reesejames
Dec 12, 2009 08:14 PM
silverriff
Jun 2, 2008 12:26 PM
78cutlass
Feb 8, 2008 05:23 AM
