distributor vacuum control advance
Old July 21st, 2011, 06:44 AM
donald8619's Avatar
Need help to locate this valve for 71 442 Valve sits at front of intake.Has three vacuum hoses at the side one on top plus electric connection on top.Also need heater hose 5/8 in from heater to heat valve.this is a molded hose?Thanks Don
donald8619 is offline
Old July 21st, 2011, 06:59 AM
Tony72Cutlass'S''s Avatar
Is yours broken? As i know they are pretty hard to find (Only i believe standard on 71-72 models) if you go on rockauto you can find all kinds of other valves.. just not this one. Hopefully someone around here will have an extra lying around for you.
-Tony
Tony72Cutlass'S' is offline
Old July 21st, 2011, 07:46 AM
That's a known tough one to find.
Are you doing a full restoration?
'Cause if you're just trying to fix it up and drive it, that valve is completely unnecessary.
MDchanic is offline
Old July 21st, 2011, 07:56 AM
TripDeuces's Avatar
Is that the Thermactor valve? Has a name something like that.
TripDeuces is offline
Old July 21st, 2011, 08:07 AM
Yo, it's this one.
-Tony
Old July 21st, 2011, 08:09 AM
So I may not need to have this one hooked up either? I know it's purpose is to decrease temperature at idle by circulating more fluid, and at cruising speed, but apart from that, would ported vacuum do something similar?
-Tony
Old July 21st, 2011, 08:42 AM
Lady72nRob71's Avatar
Do a search on here for transmission controlled spark (TCS) solenoid - it is an emission control that is better left unhooked. Lots of threads on this thing.
Run disty right from manifold or ported vacuum source (your choice). I am running manifold vac.
Lady72nRob71 is offline
Old July 21st, 2011, 09:19 AM
dc2x4drvr's Avatar
I have of few of those in my parts collection. You can delete it, and use a brass plug in your intake.
dc2x4drvr is offline
Old July 21st, 2011, 04:53 PM
You DO not need to have it hooked up.
Its purpose is to allow GM to set the timing all screwed up, and still have the car run and not overheat. All it does is allow the engine to run normally under extreme conditions (too hot, and top gear cruising) while having it run messed-up the rest of the time. If you don't use it, you can just set your timing to be correct for the entire operating range, and never look back.
MDchanic is offline
Old July 22nd, 2011, 06:42 AM
And this would be through a re-curve kit, right?
I bought a Mr. Gasket Re-curve kit to install once i get the car running (only one available up here in Montreal), but a couple guys said it'd be better to get another more reliable brand..
-Tony
Old July 22nd, 2011, 06:57 AM
I would have to check my Motor manuals to compare the mechanical and advance curves for the years with snd without these settings, but basically, the best thing to do is probably a careful trial an error recurve, but you can probably get close by just removing all the unneccessary plumbing and setting your timing as though your car were a 1970 model.
MDchanic is offline
Old July 22nd, 2011, 07:07 AM
Okay that sounds good, it's just hard to believe that i'll be able to get close with those 6 springs that there are in a re-curve kit..
Any input on that would be great! I've only got the CSM/fischer manual from 72.. all it really has on timing is this picture here in the emmissions section.
Thanks,
Tony
defiant1
August 4th, 2014 09:15 PM
70W30Jim
December 27th, 2013 12:33 PM
Octania
December 14th, 2013 08:34 AM
teqdave
December 7th, 2013 06:53 AM
pcard
February 11th, 2013 05:09 PM
Quick Reply: distributor vacuum control advance
