Sx 455
I believe that there are at least a couple threads on this site discussing the three 1970 SX 455 engines.
Terry
From what I know, and it may not be totally accurate, is that the W32 was the same as the 455 4bbl, as used in the 442, which had 10.50:1 compression (365hp/500lb ft.), while the L31 had 10.25:1 compression (365 hp/510 lb ft.). But, the horsepower and torque are given at different rpms.
Yes, they are different. Again, the L-31/OD TH400 in your SX was the same as the 455 used in full size cars like the 88 and 98. Your 442 has the same engine/OG trans as the W32 SX (this same engine in the 442 was not designated with the W32 code however.). They're not the identical drivetrain.
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
