455 Parts
Old Jan 5, 2011 | 01:15 PM
Stevec's Avatar
455 Parts
I bought a bare 455, I managed to find the following on Ebay. Timing cover,crank pully bolt,oil slinger, fuel pump ecentric,distributor hold down,crank key,freeze plugs. Is there anything else that I am going to need when it is time to assemble this engine? This is my first ever Olds build so any info would greatly be apreciated. Thanks
Old Jan 5, 2011 | 02:42 PM
Beob's Avatar
My block was missing the lifter galley plugs. I think there is 3 maybe more, one of them feeds oil to the distributor.
Old Jan 5, 2011 | 02:45 PM
cutlassefi's Avatar
One of the other ones sprays the chain and gears.
Oil filler tube? Oil filter adaptor? And you may not be able to use the slinger depending on what chain setup you use.
Old Jan 6, 2011 | 04:23 AM
507OLDS's Avatar
I guess the question is how bare is that block?There are some misc plugs & such,but maybe they are still on it.
Old Jan 6, 2011 | 01:53 PM
Stevec's Avatar
It was all cleaned and machined and then sat for about 5 years because the guy lost interest. I now have to get it cleaned (hot tanked) and Ill have it all measured and inspected.
Old Jan 6, 2011 | 03:27 PM
My442's Avatar
I have the plugs for the front, including the one with the squirt hole....it's NOS.....
Old Jan 11, 2011 | 07:29 AM
hellnback's Avatar
I've got oil filter adapter(s) old points distributor they need a new home
gearheads78
Feb 29, 2012 08:11 PM
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
