455 Parts
455 Parts
I bought a bare 455, I managed to find the following on Ebay. Timing cover,crank pully bolt,oil slinger, fuel pump ecentric,distributor hold down,crank key,freeze plugs. Is there anything else that I am going to need when it is time to assemble this engine? This is my first ever Olds build so any info would greatly be apreciated. Thanks
Oil filler tube? Oil filter adaptor? And you may not be able to use the slinger depending on what chain setup you use.
It was all cleaned and machined and then sat for about 5 years because the guy lost interest. I now have to get it cleaned (hot tanked) and Ill have it all measured and inspected.
gearheads78
Feb 29, 2012 08:11 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
