67 442 Engine
67 442 Engine
Picked up an engine this weekend for my car. My car had a 330 in it when I bought it years ago. Wanted to at least have a correct engine for the car as a spare, building a 455 currently. Anyway, the engine had been sitting awhile and had three bent pushrods, guess someone tried to start it recently. As long as there is no cracks anywhere, I assume it's rebuildable. Lots of rust but mostly surface. The cylinder walls look okay. I need to pull the pistons tonight. Couldn't pass it up for $500. I'll keep the valve cover with the sticker on it as is, never seen an original or what looks like an original sticker.
It is from a 67-442 judging by the C heads. In case you don't already know, squirt penetrating oil like Kroil or Mopar rust penetrant spray around the bores. Knock out the pistons and rods by putting a rod against the bottom of the pin bore of a piston, not the bearing surface of the rod.
Very cool. I hope you're planning on bringing at least one of those to our show in Rockville on Aug 14:
https://classicoldsmobile.com/forums...-aug-14-a.html
njot33
Sep 25, 2009 09:07 AM
cts-v
Jan 10, 2009 06:20 PM
