Edelbrock Torker, your thoughts?
Old Apr 13, 2010 | 12:15 AM
Prsabordo's Avatar
Found a torker for cheap for a stock 455, will this be a good setup for the olds along with a quadrajet? I read the torkers were meant for higher RPM, like 2500-6500. But i heard that the olds 455 motors shouldn't be pushed passed 5k for periods of time or else it will suck the oil pan dry and i will lose the bottom end. Is this true about taking the motors pass 5k, if so, what intake manifold would you recommend? Also what quadrajet should go with the Torker if i went with it?
Old Apr 13, 2010 | 05:02 AM
MN71W30's Avatar
If you got a relitively stock 455 I think you should stick to a dual plane manifold. I tried the torker before on a stock 400 and wasn't impressed. Jmho
69CutlassAlex
Jul 30, 2013 08:18 AM
455cutlass1969
Apr 9, 2012 11:13 AM
Prsabordo
Apr 14, 2010 04:57 AM
Topless72
Nov 20, 2008 08:13 PM
