Bronze Dist Gear
Old Mar 26, 2010 | 01:36 PM
CHRISH8846's Avatar
Bronze Dist Gear
I know from general info that if you have a hydraulic roller cam (except Crane) you need a bronze dist gear. Why??
Old Mar 26, 2010 | 01:41 PM
Run to Rund's Avatar
It is about the material used for the camshaft core. Cast iron cores use the factory type gear. Bronze or composite (Comp Cams) will be needed with steel cores.
Old Mar 26, 2010 | 01:55 PM
CHRISH8846's Avatar
So my Comp Roller is steel, I guess thats why it's so pretty.
Old Mar 26, 2010 | 05:31 PM
cutlassefi's Avatar
You both are partly right. Crane was the first to use pressed on cast iron gears on their roller cams. They supplied the cores for alot of people in their hayday, Comp, everybody. The reason you use a bronze gear is so that the distributor gear wears out before the cam gear does. Which one is cheaper to replace?
And btw, most Comp cams hydraulic roller cores are carborized cast steel not billet. If it were a flat tappet it would have to be parkerized, hence the dark color. Roller doesn't need that process.
Old Mar 26, 2010 | 05:44 PM
CHRISH8846's Avatar
Hence my train of thought on this topic,MSD only has six gears left but Comp has lots,I'm thinking about having my local machine shop shave the MSD dist shaft .009 and using Comp bronze gears. The MSD shaft is .500 and the std. shaft is .491. The roll pin holes look to be in the same place, or I could have the gears enlarged each time a replacement was needed.
Old Mar 26, 2010 | 05:54 PM
cutlassefi's Avatar
Just enlarge the gears.
Old Apr 15, 2010 | 03:33 PM
greenslade's Avatar
The gear on my dist is a little loose and I can see a little movement at the roll pin is this normal.Just though I would ask seen how we are on the subject.If not normal then what's the fix?
Old Apr 16, 2010 | 02:33 PM
CHRISH8846's Avatar
You should not have any play, it should be tight on the gear.
lyev
Jun 14, 2015 04:08 PM
crholds442
Feb 16, 2015 12:03 PM
e129745
Jun 26, 2012 08:06 AM
panos
Jul 12, 2010 10:22 AM
dan1s
Oct 1, 2008 05:30 AM
