Best Fitting Headers for BBO in a 65 Cutlass
Old Feb 19, 2010 | 12:05 AM
rcdynamic88's Avatar
I've got a 65 Cutlass with a 455 and I am have the Doug Thorley PN-331 ceramic coated headers. They were beautiful...but I had to hammer on them to get clearance around the steering shaft. Every where else was a perfect fit (I also have to use one of the mini starters). But I hate looking at that spot I had to modify to get past the shaft. Anybody out there use a header that fit without having to bang a dent into them to fit correctly? I have a nice 3" exhaust system with the Pypes "X" pipe and Flowmasters, so I'm looking for a set with 3" collectors. Thanks for any information.
Old Feb 19, 2010 | 03:11 AM
Mongoose's Avatar
I know this doesn't help... but I haven't had a set yet that doesn't have a clearence issue some where. The 64-65 chassis are so narrow compared to later models... there is just not much room for a big block. Occasionally you'll read about someone you had a set they didn't have to bend, but I think there is such a "loose tolerence" in the build of each set a manufacturor produces, that a different box of the same part number would end up hitting somewhere.
I am in the same situation right now. I've got a brand new engine with brand new shiny ceramic coated headers sitting between the frame rails on my 65. I've got 2 or 3 spots I've got to deal with. Fortunately the entire front clip is off the car, so I hope that I have clearence to the various spots to carefully bend them enough to keep the headers off everything.
I was told these are the best fitting headers for a 65.... WHATEVER. Same as all the others I've had.
Old Feb 19, 2010 | 05:35 AM
70 cutlass s's Avatar
Every once in a while you get a set that fit, but most of the time you have to make them fit.
Old Feb 19, 2010 | 06:30 AM
Kooks headers (now sold by Dick Miller) fit the best. They ain't cheap.
Old Feb 19, 2010 | 08:56 AM
copper128's Avatar
Lt. Buzzkill (ret.)
2" Kook's didn't fit well at all on my 67 442. They hit the crossmember on the RH (major interference), hit the firewall on both sides, block access to the LH motor mount bolt and make starter and dipstick tube installation almost impossible.
All at a cost of over $700. Sheesh.
Fullsizelover
Nov 26, 2014 07:30 AM
olds 307 and 403
Apr 13, 2014 09:25 AM
Wyze
Mar 18, 2012 01:59 PM
dar83501
Nov 20, 2007 11:45 PM
dar83501
Oct 14, 2007 12:35 PM
