Dyno Coming Soon - 488
Engine build progress is nearly finished.
I pulled the original 400 out of my 1969 442 and will be replacing it with this 488, painted in the original 400 color.
Torker Intake ported and matched
Holly Quickfuel 850
Edelbrock Performer RPM Heads (re-worked)
10.5:1 Compression
CAM specs @.050 242/250 110LSA, swapped 4/7 firing order
The torker is a spreadbore, so we will determine with adapter is best while on the dyno - open or the 4-hole.
Holly Quickfuel 850
10.5:1 Compression
EDIT--- we are at 477 Cubic Inch, not 488- I had my math wrong.
Engine is officially dyno'd and broken in.
We tried different carb set ups, spacers, and had a snafoo with an HEI distributor that led me to run an MSD instead.
We ended up using the open bore spacer vs the 4-hole.
Enjoy the video!
It came in at 550hp and 566 tq - a very respectable amount for a street car
Olds Performance supplied the offset ground crank and internally balanced the rotating assembly.
The bottom end does have main cap straps, and I know there are a lot of opinions about those.
Enjoy the video!
Dyno conditions were not favorable-
high humidity, corrected altitude at 2800 ft., and 1 3/4 headers resulted in the lower numbers.
I do feel with larger headers, cooler air, and at lower altitude it would be in the 600s.
What was the correction factor? Do you have fuel consumption numbers etc.?
And how old is that QF carb?
Thanks.
you’re the expert!
the carb is brand new
You made 489hp measured, CORRECTED was 550 so your correction factor was about 11-12%. Like I said, corrected power is just that, it’s already corrected for the weather conditions of the dyno session. So if the weather was better, it would change your measured horsepower, but not your corrected. Bigger headers however would most likely add to both.
And now based on your a/f numbers, I had a feeling it was newer QF carb. They’re not what they used to be, unfortunately.
i might try to hunt down an older one- appreciate the input!
Well, I can tell you without hesitation, that every engine I’ve put these on, without exception, has made more power. Most times it was double digit power.
BUT, they do require tuning. Buy a wideband and a jet and bleed kit and you’ll be equipped to do it right.
ask around about who at Holleys tech is the best to get advice from. have all your data from the dyno session available when you talk to them about the afr during the pulls.
that’s all free ..you’ll also learn some basics about tuning your own carb
Will do - this is my carb:
Quick Fuel Street-Q 850 CFM 4-Barrel Carburetor SQ-850
Given these readings are at WOT, how would the AFR compare when normally street driven? Say about 1/4-1/2 throttle?
