Upper Hose on 455 collapses at cool down
Old Sep 19, 2024 | 12:08 PM
radiofellow50's Avatar
Do I have an issue to address or is this normal? See Pic. The upper hose off the radiator to the block collapses after the engine cools down, or at rest.? Is that normal.
Old Sep 19, 2024 | 12:25 PM
70sgeek's Avatar
'72 Cutlass ragtop
Maybe you have a vacuum / blockage condition being created during those periods which is sucking the hose in. Maybe try bleeding/burping your cooling system the cap off.
If the hose is old, try changing it out. It not too old, maybe put a spring in it like bottom hoses have.
Old Sep 19, 2024 | 12:29 PM
Also check the radiator cap. Does this car have an overflow jug or just a puke hose?
Old Sep 19, 2024 | 12:35 PM
Your radiator cap may be faulty.
Old Sep 19, 2024 | 12:42 PM
New hose and has a overflow jug.
Old Sep 19, 2024 | 12:44 PM
Just put a new hose on old one did the same thing.
I'll try "burping the system" and also try a new cap?
Old Sep 19, 2024 | 12:46 PM
Is it an overflow (like puke bottle) or a coolant reservoir where coolant flows back into the radiator when needed. As a reservoir, there should be little to no vacuum on the system when it cools, so it makes the cap suspect.
Old Sep 19, 2024 | 01:12 PM
Changed out the radiator cap with a new one from NAPA (16lbs pressure rating). We'll give that a try. The other one was marked 0.9!!
I'll post when I take the car out again and run it and see if it does the same thing.
Thanks for replys.
Old Sep 19, 2024 | 01:34 PM
Sugar Bear's Avatar
The 0.9 was probably 0.9 bar or around 13 psi.
Old Sep 19, 2024 | 02:07 PM
69HO43's Avatar
Is your new radiator cap made for recovery? Most are nowadays, but there's also ones that do NOT have the vacuum break that were made for non-recovery situations.
Old Sep 19, 2024 | 03:15 PM
Here's what the website says....I think I'm OK - your thoughts?
Bob
Napa #703-1699
  • The SWIV-EL design allows the cap to be installed and removed much easier than conventional radiator caps. Meets original equipment specifications.
  • Made from premium materials. Designed to function on open cooling systems and overflow reservoir type systems.
  • 100% tested to ensure proper pressure and longevity
  • Meets all OEM specifications
Old Sep 19, 2024 | 04:33 PM
Tri-Carb's Avatar
Insert a hose spring.
Old Sep 19, 2024 | 04:37 PM
66_Jetstar's Avatar
Move on and live your best life. No issue here.
Old Sep 19, 2024 | 05:44 PM
Thanks I think I'll do that. Sometimes it's the little things that annoy me, but this just doesn't seem right (the hose collapsing). I did get that new cap too.
mclark68442
Mar 31, 2023 02:46 PM
chip-powell
Apr 20, 2017 07:24 PM
cutlassquad
Apr 12, 2013 08:57 AM
terrapin
Mar 17, 2013 10:37 AM
OldsManNJ
Mar 23, 2011 08:47 AM
