400 Eng Oil Plugs
400 Eng Oil Plugs
Question is about the three oil plugs, 2 in the front, one in the back on my 66 442 400ci engine.
Based on what the machine shop said (and the rebuild book (sa502 Cartech Inc), their is one plug with the hole in the center that goes on the right side of the engine (passenger side) to lubricate the timing chain, the left side is the same plug without the hole, and the plug in the rear of the block (inside the engine behind the freeze plug) is just a plug.
Just want to verify this before I start the build process.
Tom
Tom
The two in the front with the hex heads are different sizes and can only go in one way.
Tom
Tom
Thanks for all of you responses…….now the problem is where to get one of those rear plugs withe hole in it.
The machine shop doesn’t have it and said the plug was already out, which is entirely possible as the block was completely torn down/stripped when I bought the car.
I’ll call some other machine shops to see if they have one, but if anyone has a place to source this plug, let me know.
Tom
Tom
Tom,
That one is easy. Its just a 3/8 pipe plug with a .040" hole drilled in the middle. Your machine shop should have plenty of 3/8 pipe plugs. Then all you need is a teensy .040 drill bit. I dont think I have ever see the predrilled plug anywhere but I really have not looked very much.
Bill, that what I’m finding out…..no one sells them.
i did find a local machine shop who would drill the hole in the right size plug…….that was going to be my next question which you answered .
I will give him the info and get it done.
Thanks for the help! Much appreciate!
Tom
Tom
85Cutty442
Nov 18, 2016 03:10 PM
