Main bearings id
Old Nov 4, 2023 | 08:17 AM
PaulWinn's Avatar
Main bearings id
I am tearing down my 455 to fix some oil leaks and plan to do a re ring and bearing job. Question though - I am used to seeing the std or oversize marking on the back side of the bearings. My Clevite rod bearings are indeed marked .010 over but none of my mains have an indicator. Some online info say these are .010 over but why doesn't it say on there?
Old Nov 4, 2023 | 12:04 PM
OLDSter Ralph's Avatar
I would guess they are "standard" and shouldn't need marking to denote other than OEM size. Did you "mic" the journals to verify journal size ?
Old Nov 5, 2023 | 06:52 AM
PaulWinn's Avatar
Usually standards are also marked and read "std" - usually. I'll borrow a mic and check k it out. Are 1, 2, and 4 mains the same?
REO442
Dec 29, 2021 08:30 AM
Doug Carner
Feb 25, 2020 07:51 PM
Tjohn8573
Aug 16, 2019 01:49 PM
pogo69
Mar 3, 2014 06:25 AM
65w30
Aug 5, 2011 01:35 PM
