K Head and Ka head differences?
Old Jun 7, 2023 | 08:04 PM
Bernhard's Avatar
What is the difference between a K and a Ka heads?
Where they both only for marine and agriculture use?
Is one an earlier production?
Old Jun 8, 2023 | 05:23 AM
Andy's Avatar
Not sure, I thought I heard K heads were also F head warranty replacement heads.. Somebody will correct that cuz its from memory, so not 100% on that
Old Jun 8, 2023 | 06:04 AM
K and KA heads were primarily for marine and industrial uses, but were used on some of the L77 motors in the mid-70s.
The "warranty replacement" story is not quite what it seems. GM routinely superceded part numbers in the parts network as older stocks ran out and were replaced by later articles (witness the "dimpled" 1971 front fenders being shown as superseding the 1970 flat fenders). That does NOT mean that the new replacement part number is identical to the old one, only that it will work to keep the car running. For a few years following the model year of production, the same factory style heads were still available in the parts network - D, F, and H heads could be purchased over the counter. By the mid-1970s, the only BBO head castings left in the parts network were the J and K/KA castings. J heads were shown as superseding all regular-performance heads and KA heads were shown replacing all performance heads. This does not make KA heads direct replacements for F or D or H heads. It only means that they were the best replacement available at the time. NHRA stock class specs accept KA in place of the original performance heads because the KA's don't provide any advantage over the originals (which is NOT to say that they don't provide a DISADVANTAGE).
Old Jun 8, 2023 | 06:19 AM
1969Hurst's Avatar
I have Ka heads on my 1974 Hurst/Olds, not the best pic but you can make it out...
Old Jun 8, 2023 | 08:14 AM
Andy's Avatar
So as far as the same runners, combustion chamber cc and all were they identical? Or?
Old Jun 8, 2023 | 08:22 AM
Unfortunately I don't have that comparison data. I'd suspect that all the BBO head combustion chambers are in the 80-84 cc range as cast, with the possible exception of the D heads. Runners are likewise similar except for Js. I'll have to look at my Ks to see if the one crossover is blocked.
Old Jun 8, 2023 | 06:10 PM
Bernhard's Avatar
Thanks for the replies.
Old Jun 9, 2023 | 12:29 PM
ourkid2000's Avatar
Just curious, what does BBO stand for?
Old Jun 9, 2023 | 12:34 PM
Big Block Olds
Old Jun 9, 2023 | 04:03 PM
Beyond Body Odor.
Old Jun 10, 2023 | 04:27 AM
ourkid2000's Avatar
Beyond Body Odor.
Bottom bottle opener? Remember those?
Bee Saint Louis
Sep 22, 2022 11:58 AM
GN1220
Feb 8, 2022 08:15 AM
brownbomber77
Jan 15, 2017 05:45 PM
mkpola
Feb 10, 2013 03:41 PM
boondocker
Jun 18, 2011 12:29 PM
