cylinder head
Old Nov 9, 2022 | 10:47 AM
doggonn's Avatar
cylinder head
anybody out there have any feedback on the site oldsrocketparts they advertise aluminum heads , are they any good ?
Old Nov 9, 2022 | 10:59 AM
cutlassefi's Avatar
They’re repackaged Speedmasters.
I don’t know how well they go thru them but I’ve been told by many the advertised chamber cc’s are seldom correct. Conversely I can tell you first hand the stock valves and valve job are actually ok. However the stock valve springs are total and complete junk. That isn’t an Olds Rocket Parts issue, but unless they replace them you’ll be taking your chances.
Old Nov 9, 2022 | 11:21 AM
doggonn's Avatar
thanks for the input my problem with my A heads i have are rocker arm is running on outside center on valve stem . nee a shorter pushrod but then rocker will botto out and hit. using rollertp rockers with 3/8 by 3/8 studs and i believe 3/8 pushrods any suggestions on a fix ?
Old Nov 10, 2022 | 07:09 AM
67OAI's Avatar
Old(s)GuysRule
How thick are the guide plates and were the heads milled to compensate for that? Sometimes 1/16" thick guide plates will not require milling of the rocker pads. What brand/part number rockers are you using? This information will help to get answers to your problem.
71DP
Apr 12, 2017 04:41 AM
Arrowstorm
Jan 27, 2015 03:38 PM
ctsplicer
Aug 4, 2014 01:35 PM
jag1886
Dec 18, 2013 03:43 AM
Erinyes
May 5, 2013 03:25 PM
