Flywheel Issue
Old Dec 25, 2021 | 09:23 PM
Owen Gluch's Avatar
Flywheel Issue
Long story short, when I had my engine done I received a 0 balance flywheel back somehow. My engine is not internally balanced so this is an obvious issue. Is there a plate or something I can use in pair with the 0 balance flywheel to achieve the correct balance? Or am I stuck having to buy a new flywheel? Thanks in advance.
Old Dec 27, 2021 | 06:20 AM
oddball's Avatar
Just to check - flywheel for a manual transmission, or flexplate for an automatic?
Every external flexplate I've seen has a welded-on weight.
*Some* flywheels use a bolt-on weight. Do you know the specific flywheel? I bought a cheap one just for use on the dyno that used a bolt-on weight. My engine is internally balanced, so I just took off the weight and threw it into a drawer .... somewhere. Would be funny if yours is the same one!
Did you supply a flywheel to the shop? The whole assembly has to be balanced together and while there is a "spec" it's certainly best to use the parts that were there for the balancing.
Old Dec 27, 2021 | 08:29 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The machine shop should have provided a balance sheet. Mine did, ask for it, it should have the weight added and the final balance weight.
Old Dec 27, 2021 | 10:20 AM
BillK's Avatar
Owen,
First of all, what engine is it ??
Did you supply a flywheel to the machine shop to use with the assembly when they balanced it ? You really need to find out what they did before you buy anything. Are you absolutely certain the flywheel you have is internal balance ? Are you sure they did not internally balance the engine ? Can you post a picture of it, especially the side that goes towards the engine ?
I really think you first call should be to the machine shop.
67Rocket
Apr 29, 2017 09:01 AM
1970442
Dec 12, 2013 01:45 PM
young olds
Jun 4, 2013 07:58 AM
Aceshigh
Feb 24, 2010 07:15 AM
flatoz
Apr 24, 2008 05:59 AM
