jones cams regrind question
Old Sep 30, 2021 | 10:09 PM
arcticman's Avatar
Hello everyone, ive been rebuilding a 455 using Marks recipe and advise. wanting to hit 450 hp stock heads, manifolds, and carb. my block work is done. Im needing to order my camshaft. Mark recommended something in the low 230s 112. Anyway i contacted a company called Jones cams and Mike Jones recommended i send him the original cam for a regrind. based on the fact i might not be able to get a core due to supply. My question is this: is this a good way to go. my original cam is the stock cam out of the 1970 toro
Thanks for your input
Old Oct 1, 2021 | 12:22 AM
OLDSter Ralph's Avatar
Mark who ?
Old Oct 1, 2021 | 04:48 AM
cutlassefi's Avatar
I think that’s me.
Op- I can get flat tappet cores.
Old Oct 1, 2021 | 08:32 AM
arcticman's Avatar
Goodmorning, Yes it is. you have been very helpful in moving this engine build forward.Thank you for your time and advice. my questions werent answered directly but I can assume since you have access to cores that regrinding is ok or in the case of a new core maybe custom grind would be a better description. I would like to purchase a core from you if possible. let me know what you need from me. also your recommendation on who to use for grinding.
Thanks again
Old Oct 1, 2021 | 09:28 AM
Thanks again
Why don't you just contact Cutlassefi about the cam ? Why Jones Cams ? Why regrind a cam when you can get a new one ground ?
mother$hip89
Feb 15, 2018 08:59 PM
DENT
May 13, 2015 06:53 AM
Napoleon Solo
May 5, 2015 10:53 PM
young olds
Jan 2, 2014 07:36 AM
MDchanic
Mar 26, 2013 03:15 AM
