What cam ?
Old May 12, 2015 | 06:13 AM
DENT's Avatar
What cam ?
I know its been asked a thousand times but , if I have a stock 1972 350 , little bit of port work on the heads , stock valves stock intake and exhaust manifolds .
What cam would you use?
Old May 12, 2015 | 06:18 AM
84oldshurst's Avatar
I put in a comp cams XE268H.
The car has a noticeable idle but can still run A/C and other things just fine. But I'm no expert on what to recommend. This is just what I used
Old May 12, 2015 | 06:54 AM
70cutty's Avatar
Beer Connoisseur
PM cutlassefi - Mark, he can grind you a custom cam tailored to your engine for about the same price that off the shelf cams go for. Great guy to deal with.
Old May 12, 2015 | 07:12 AM
I would think that's a bit much. I've got a 262H in my 10.5-1 G-block and that seems about right. With 8.2-1 compression, you probably don't want to go over 215 degrees (@ 0.050) duration or 0.460 lift.
Old May 12, 2015 | 07:32 AM
I'm sorry, I didn't clarify what engine mine is.
Mine is a 1969 with #5 heads and it has 10.25-1 compression.
Does that make more sense?
Old May 12, 2015 | 07:53 AM
1BOSS83's Avatar
x2
I'm putting a 268h in my 70' 350 9.6:1 right now and if I could go back I would've got something custom from Mark R. I also agree that the 268 is a bit much for anything in the 8-8.5:1 range. Talk to Mark about the piece and Don (80Rocket) is also a great resource. Good luck
Old May 12, 2015 | 09:13 AM
Definitely. I'm guessing OP's engine is 8.2, though.
Old May 12, 2015 | 10:24 AM
DENT's Avatar
I might do that , thanks.
Old May 12, 2015 | 11:28 AM
cutlassefi's Avatar
What's the rear gear?
Old May 12, 2015 | 01:49 PM
1BOSS83's Avatar
What are the details about the remainder of your drive train out of curiosity?
Old May 13, 2015 | 06:53 AM
DENT's Avatar
TH 350 with a shift kit , 2200 stall converter , 342 rear gear,
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
72RocketPower
Aug 11, 2005 04:51 AM
Rocketman
Nov 22, 2004 01:59 PM
