Engine shaking at idle
Old Feb 1, 2021 | 08:45 AM
KaydenST's Avatar
I replaced the radiator and had the harmonic balancer rebuilt and reinstalled, and painted the intake manifold while on engine (removed carb and other linkages and bracket and taped everything off), and now the engine shakes at idle. Set dwell, timing, idle fuel mixture, doesn't really improve. Any ideas? Carb was rebuilt, but was rebuilt and run before changing balancer and radiator and painting, and was running very smoothly. I'm thinking maybe the carb is flooding? There is also wispy smoke that comes out of the carburetor vents while running. Thanks for your help!
Old Feb 1, 2021 | 09:26 AM
KaydenST's Avatar
Car is a 1966 Toronado, sorry, forgot to mention
Old Feb 1, 2021 | 09:58 AM
gs72's Avatar
72Cutlass S
Could be your rebuilt balancer is out of balance. pay attention to the frequency of the shaking. Is it at crank speed or half crank speed. the balancer or a out of balance problem will cause a vibration at crankshaft speed/rpm, while a ignition or fuel problem will cause a will cause the engine to shake at half crankshaft speed as the cylinders fire every other revolution.
Old Feb 1, 2021 | 10:04 AM
I'd look at whatever got removed and replaced. I assume the carb came off to paint the intake. My money is on a vacuum leak.
Old Feb 1, 2021 | 10:48 AM
KaydenST's Avatar
I thought of that too... The thing is, I sent the balancer out to be rebuilt, and he aligned the outer ring to stock specs (inline with the crank keyway), so I wouldn't *think* that's the issue. It looks to be the correct balancer for the Toronado 425 (the "half moon" balancer). The only way I could see it being incorrect is if the previous owner had put a 330 balancer on the car, which I *think* has a different counterweight (correct me if I'm wrong)
Old Feb 1, 2021 | 10:49 AM
KaydenST's Avatar
I'll have to remove the carb and check the gaskets and check for warpage
Old Feb 1, 2021 | 10:50 AM
The 330 balancer is the same.
Old Feb 1, 2021 | 10:52 AM
Before that you should put a vacuum gauge on the engine and see what the vacuum reading is at idle. Also look for any loose or mis-connected hoses. Verify ignition timing. Verify spark plug wires didn't get crossed. Again, what got taken off when you did all this work?
Old Feb 1, 2021 | 11:01 AM
KaydenST's Avatar
I thought the 330 balancer has the timing mark at 9:00 relative to the keyway, and the 425 balancer has the timing mark at 12:00 relative to the keyway?
Old Feb 1, 2021 | 11:04 AM
KaydenST's Avatar
The carburetor was removed, as well as vacuum lines. I only disconnected plug wires from the spark plugs because I removed and painted the valve covers as well. I'll double check to make sure I reconnected all the vacuum lines and make sure I reconnected the plug wires correctly. I get a vacuum reading of 15 inHg, but I am at 4,300 ft. elevation.
Old Feb 1, 2021 | 11:33 AM
1964 is the only year that the 330 balancer is different due to the one-year-only driver-side water pump inlet. If your car had a 1964 balancer on it, you'd never have been able to set the timing in the first place.
Old Feb 1, 2021 | 11:35 AM
KaydenST's Avatar
Gotcha, good to know
Old Apr 27, 2021 | 08:36 PM
KaydenST's Avatar
Hey all, so I haven't been able to work on the car very much lately, but I found the source of my problem earlier today. I thought I'd post it up in case someone else has a similar problem. I feel stupid for not checking this out in more detail before, but a vacuum line had come loose in a spot I hadn't even thought to check, because I never touched it when I painted the manifold. It was at the vacuum tee under the driver side hood hinge where the headlights and I presume heater controls get their vacuum from. Thank you all for your help, car runs real smooth once again.
Old Apr 28, 2021 | 05:05 AM
leftlaneonly's Avatar
Finding the problem and fixing it is half the fun...Drive on
Haidda
Aug 5, 2017 01:32 AM
377rick
Jul 24, 2014 06:35 AM
navvet
Apr 26, 2012 10:09 PM
al714
Nov 13, 2011 11:24 AM
fmay50
Dec 9, 2009 02:54 PM
